Hello guys,
I saw this video of Rundeck on youtube and testing it. But I didn’t see any plugin that work for Docker Run step. https://www.youtube.com/watch?v=KiezNnXYBH4
Is there any plugin for docker run step ?
Hello guys,
Hi Tun!
Yes, the plugin is available here, and here you can download it. You can put the zip file ( docker-container-1.4.5.zip) on the libext directory or upload it directly through Plugin Manager (Gear Icon > Plugins > Upload Plugin).
After that, the docker steps are available for any job.
Hope it helps!
Hello Reiner,
I saw that plugin already. This is a built in plugin for enterprise right? But I didn’t see docker either in work flow step or node step.
Best Regards,
Tun Lyin Aung
Attached my screen recording as a proof.
Hi Tun, the plugin isn’t built with PagerDuty Process Automation On Prem (formerly “Rundeck Enterprise”). To use it please install it following my first answer.
Hi Reiner,
now , I see the workflow step but I got errors when I run. I think that error is because of no sudo access. But I have sudo access for ec2-user. You can see first workflow step that creates file in root directory using sudo access is Okay. But the docker run image step failed. Can you guide me please? I attached my screenshots to check.
Hi Tun, a good approach is to add the rundeck user to the docker group to run docker commands. Take a look at this.
Hello Reiner,
I just followed your guidance and add rundeck user to the docker group. rundeck user can now run docker without sudo in terminal. But with docker plugin, there’s still permission denied error. I will attach my screenshots.
Hi Tun,
I replicated your scenario
you need to restart the rundeck service to take the rundeck user session changes.
Here is a step-by-step from scratch using the Amazon Linux EC2 image:
sudo yum -y update
sudo yum install docker
sudo docker ps
amazon-linux-extras install java-openjdk11
framework.properties and rundeck-config.properties files accordingly to your external DNS/IP info.systemctl start rundeckd
- defaultTab: nodes
description: ''
executionEnabled: true
loglevel: INFO
nodeFilterEditable: false
plugins:
ExecutionLifecycle: null
scheduleEnabled: true
sequence:
commands:
- configuration:
debug: 'false'
image: nginx:alpine
publish: 8080:80
nodeStep: true
type: docker-run-workflow-step
keepgoing: false
strategy: node-first
uuid: bae6117f-d85e-478a-b333-356d3568816d
See the permissions error.
rundeck user to docker group: usermod -a -G docker rundeck
systemctl restart rundeckd
Hope it helps!
Hello Reiner,
The permission denied error is completely okay now. Can I ask how to use running docker container as our nodes. Is there any example for these parameters please ?
Hello Reiner,
Now it’s okay to use running containers as nodes. I got it now. Can you help me one more please? Is there any plugin related in the following screenshot please? I searched it in the rundeck plugin site and I didn’t see any. It would be great if you help me along with this.
Hi Tun,
That’s an old custom plugin for an ancient Rundeck version, currently, you can use the SQL Runner plugin (built-in with Process Automation) to use against your rdbs, or create a custom plugin following this. Also you can use an script step to extract that data like this.
Regards!
Hello Reiner,
I will figure it out the SQL Runner plugin. Thank you for your time and guidance for these issues. Really appreciate it.
Best Regards,
Tun Lyin Aung
Anytime Tun!
Hello everyone, can you help me? I’m having trouble getting the docker run workflow plugin. I’m using ubuntu on an EC2
Hi Thiago,
That happens when you try to import a job but the plugin doesn’t exist in your Rundeck instance. You can get the latest version from here and donwload the docker-1.4.7.zip file on the /var/lib/rundeck/libext directory.
The quickest way is to use the wget tool:
wget https://github.com/rundeck-plugins/docker/releases/download/1.4.7/docker-1.4.7.zip -P /var/lib/rundeck/libext
In that way the docker step should be available and you can upload your Job Definition.
Regards.
